Edge Gear Ratio
Old Jul 11, 2011 | 05:58 PM
detroitbuilt's Avatar
Registered User
Edge Gear Ratio
I have an '08 STX. Recently I bought an edge programmer for my larger tires in order to correct the speedo (295/70/18). In order to fix the speedo its necessary to put in the new tire size, but to also adjust the gear ratio. I know very little about gear ratios let alone finding the new one. What should I put in for the new gear ratio? Thank you. I will probably need to give out more information in order to figure it out so just ask.
Old Jul 11, 2011 | 06:25 PM
Look at your door jamb sticker for your axel code.....then post it up here and someone will tell you what it is or do a search on" axel codes"
Click link>>>https://www.f150online.com/forums/1755513-post14.html
Last edited by 88racing; Jul 11, 2011 at 06:29 PM. Reason: added link for axel codes
Old Jul 11, 2011 | 07:21 PM
Registered User
3:73 .....limited slip?
Old Jul 11, 2011 | 07:31 PM
If it was B6....then yes 3.73 limited slip.....
Old Jul 11, 2011 | 09:32 PM
Registered User
Ok now what do I do with that
