Looking for advice
Looking for advice
So here is the scenario. I purchased a 2007 fx4 with a aftermarket exhaust (wasn't really keen on the exhaust, but I like the truck)
A few months down the road I get a check engine light (P0430 and P0420 faulty catyl convertor)
The service advisor at Ford 'ball parked" the repair at $2500! This is what he wrote on my invoice.
"Customer could go to a performance/speed shop and have a programer installed to ignore catyl convertor monitor sensors."
I am not sure what this means, looking for some advice from you f150 gurus
Lee
Lee
Complaint: Check ingine light is on
Cause: Faulty catyl converters - modified exhaust system (aftermarket)
Correction: verify cell on. eec test P0430 and P0420 pending. Both codes are for catyl converter failure. Vehicle has modified exhaust system - unable to replace factory replacement converter assys- wont fit aftermarket system. Customer could go to a performance/speed shop and have a programer installed to ignore catyl converter monitor sensors.
Advised Customer.
Below is exactly what my invoice says, I am still unsure what the technician means?
Advised Customer.
Advised Customer.
Under federal law the dealer has to replace your converters if you fall within the 8/80k mileage. If they can prove that the aftermarket exhaust caused the failure then you are screwed. If its not covered or you are out of warranty then just get a set of high flows put on and call it good. Shouldn't be any need to turn off the rear O2 monitor. Might also want to brush up on the Magnuson–Moss Warranty Act before going back to the dealer.
Dont know any Magnuson–Moss Warranty Act in Alberta?
Being that you are up north of the border you may have different emissions laws then we have in the states. If you cats are plugged then you should replace them. I would look at the 94106 high flow that many people use and go that route. Should only cost you 3-400$ maybe installed. Factory cats are extremely expensive as you can see from your dealer quote.
Thanks...
