Tuner and dead battery question
Old Feb 8, 2011 | 03:32 PM
quackrstackr's Avatar
So what happens if your battery goes bottom up and you have to change it out?
Anything?
Old Feb 8, 2011 | 03:36 PM
Veteran: Army
Anything?
yes, you have to replace the battery but it's a fairly simple task
Old Feb 8, 2011 | 03:37 PM
Veteran: Army
in fact you can even hire a shop to change the battery for you if you are unable to perform the task yourself
Old Feb 8, 2011 | 03:43 PM
Thanks, smartass.
Do you have to work that hard to be a **** or does it just come naturally?
Old Feb 8, 2011 | 03:45 PM
If you have a low battery, and you are trying to load a program, the tuner may freeze and lock down the PCM. The tuner requires lots of juice, that is why it's important to have a good battery charge before uploading a tune.
Old Feb 8, 2011 | 03:47 PM
Anything?
What tuner/programmer do you have?
If its a Gryphon or an edge disconnect it before messing with the battery...
The same goes for jump starting....
If your truck was tuned by a handheld programmer you shouldn't have anything to worry about...
Old Feb 8, 2011 | 03:48 PM
I have the Diablo Predator.
Old Feb 8, 2011 | 03:54 PM
You should be fine just swapping out the battery...
Old Feb 8, 2011 | 04:11 PM
Veteran: Army
and another one to the ignore list
Old Feb 8, 2011 | 04:12 PM
Veteran: Army
Thanks, smartass.
that's impolite...
Old Feb 8, 2011 | 04:20 PM
and so are you
Old Feb 8, 2011 | 04:21 PM
OK, guys, let it go. Jeremy, I think you asked for it. Maybe you did not understand what he was asking, but it was a legitimate question.
Old Feb 8, 2011 | 05:23 PM
Marc Carpenter's Avatar
Your adaptive stragegy start all over again, thats about it..
Old Feb 21, 2011 | 01:32 PM
bogeyrider63's Avatar
with an edge, just unplug? or return to stock and unplug? when unhooking the battery?
Old Feb 21, 2011 | 01:38 PM
Just unplug it, change the battery, turn the key on and plug it back in.
Edit: If the battery is dead, you could not change tunes anyway and you definitely do not want a bettery going low while doing a tune change.
