programmer speedometer
Old Nov 11, 2010 | 11:03 PM
2wdoffroading's Avatar
I bought a gryphon progamer a little while back, and because i had bigger tires my spedometer was off. Well i thought that i could use the speedometer on the programmer... I figured out the number for my tires to put into the programmer. (305/60/18) This speed was also incorect comparing to my gps. I figured i had made a mistake and inserted the wrong size and didnt worry about it much. But when i recieved my custum tune not long ago it still was not the correct speed. it is off by about 4mph when i am doing 60-70
what could be causing this to be off, i do not think the tire size is wrong. I thought of the gears might be entered wrong, but i am running stock gears. what are stock gears for a 2006 2wd 5.4L v8? is there something else possibly causing it to be off?
thanks for the help in advance
2wdoffroading
Old Nov 12, 2010 | 12:36 AM
What is the axle code on your door jamb sticker?
Old Nov 12, 2010 | 05:53 AM
Is it 4mph fast or slow?
The factory dash speedometer will always be 2-3 faster than the reading on the Gryphon.
You'll need to confirm with a GPS or use a different method like using mile markers.
Old Nov 14, 2010 | 12:02 AM
it is 4mph slower. and i will have to go look for the axle code
Old Nov 14, 2010 | 12:08 AM
axle code is H9?
Old Nov 14, 2010 | 12:15 AM
i just went and looked it up, the H9 says 3.55 and my programmer was set to 3.73. guess that was the problem with the spedometer
Old Nov 14, 2010 | 05:06 AM
Veteran: Army
probably
Old Nov 14, 2010 | 05:39 PM
i tested it today and it is within 1mph, so that fixed it.
thanks for the help
