Need Suggestions
Need Suggestions
Hi all
I have a 2008 f150, crew cab 4x4,5.4l, 3.73 ratio rear end, 2 1/2" hell bent spacers on front and Firestone Destination 285/65R 18 M/T.
I am looking into purchaseing a Grayphon from PHP.
Question is what do you guys recomend?
I am not a Gear Head,( not any thing wrong with GH's) and get lost in all the programing aspects.
I am just looking for help decideing what to purchase.
Should I just go stock or get some coustom tunes?
JW
JW
Hi all
I have a 2008 f150, crew cab 4x4,5.4l, 3.73 ratio rear end, 1 1/2" hell bent spacers on front and Firestone Destination 285/65R 18 M/T.
JW
JW
Then if you'd like to continue using that octane you'll need custom tunes.
Reason?
The canned tunes of the Gryphon are.....
1. Tranny only>>any octane gas can be used.
2. Tow>>87-89 octane gas only but 85 would work assuming that you're are in higher elevations.
3. Performance>>91-93 octane gas only.
So as you can see if you would like a performance tune and keep running the same octane gas, custom tunes will be needed.
Reason?
