Quick Question
Old Aug 8, 2010 | 12:53 AM
06FX4X4's Avatar
Quick Question
I had my comp flashed by Whipple when installing their SC. I then took my truck to a tuner where he used my Deablo Predator to pull the Whipple tune off my truck comp so he could put it on his comp to play around with it. My question is if I use my Predator to flash my comp back to the way it was before it got custom tuned will it install the Whipple tune back in or the F150 basic tune? I really dont want to drive around with a SC and not have the truck tuned for it. Thanks
Old Aug 8, 2010 | 07:00 AM
call your tuner, he should have records of what's what on the hand held.
Old Aug 8, 2010 | 08:04 AM
JimmysotherFORD's Avatar
it will put the Whipple base tune back in your pcm if you set the Predator to stock. the tune you got from Whipple is now your stock tune, the original factory tune is gone. so you should be fine.
if you have any other questions about the predator, PM Diablo Mike he's one of diablo's customer service reps.
Old Aug 8, 2010 | 12:28 PM
06FX4X4's Avatar
Thanks, thats what I figured, just wanted to double check.
