93 Octane - Edge Evo
Old Jul 27, 2010 | 01:58 AM
DaMoose81's Avatar
Yes i did a search and im still confused. If im not mistaken, the edge Evo lvl 3 tune was made for 91 octane. If i use 93 octane can someone please tell me what i have t adjust on it?
Old Jul 27, 2010 | 03:07 AM
Veteran: Army
just leave it alone, it will do just fine on the 91 octane tune using 93 octane
Old Jul 27, 2010 | 06:18 AM
MGDfan's Avatar
Mr. Moose;
If you insist, then .. did you search the manual? RTFM
Here ya go - page 23:
"Timing Adjustment
This timing option helps determine the final ignition timing based on
intended fuel octane rating. Modifying your timing may help improve fuel
economy as well as overall performance. However, choosing timing advance
that is too high might cause detonation (pinging), which may cause serious
harm to your engine. Lowering this value will not harm the engine but may
reduce performance and economy.
(Hint a good general rule is to increase timing .5 counts for every octane count you go up, i.e. if you are running 93 octane fuel in level three you could safely increase the timing 1.5 counts). "
Linky to manual - in case yer dawg ate yours ...
http://www.edgeproducts.com/product_...manual-277.pdf
MGD
Old Jul 29, 2010 | 02:42 AM
DaMoose81's Avatar
thanks, and ive moved 3 times since i bought the edge, Lord only knows where the manual is.
I think ill just bump it up one, is the pinging really noticeable?
Old Jul 31, 2010 | 10:01 AM
MGDfan's Avatar
It is discernable, but by then the PCM is pulling timing aggressively, thereby lobotomizing yer performance.
WHich is why TJ said to leave it alone - if you are not sure about this, it's best to have a small octane buffer to ensure you do not run near incipient ping and incur the above issue.
Consistent, high-quality fuel is important as well. As is exemplary maintenance.
MGD
