Park/nuetral rev limiter
Old Jun 9, 2010 | 12:32 AM
4.6 Punisher's Avatar
I'm sure many have noticed that on the 04+ F150's, that the rev limiter tops out just above 4000 RPM's. Is there any way to increase the limiter through my Gryphon?
Old Jun 9, 2010 | 04:22 AM
Veteran: Army
what are you doing "dry revving" it that high anyway??
Old Jun 9, 2010 | 07:01 AM
Why?
Old Jun 9, 2010 | 07:22 AM
shotgunz's Avatar
There's a way to change the RPM limit under custom options (Gryphon manual, page 16).
Unless there's two separate rev limiters? Would be a new one on me.
Old Jun 9, 2010 | 07:26 AM
NCSU_05_FX4's Avatar
If he wants to burn up his motor, let him.
A custom tune can also adjust the rev limits.
- NCSU
Old Jun 9, 2010 | 10:24 AM
Well if I have to buy another custom tune just for that, then it basically stops here.
Old Jun 9, 2010 | 12:21 PM
JMC's Avatar
JMC
25 Year Member
Reving that engine to 6500 rpm in neutral will not harm it. It will however destroy the torque converter.
Old Jun 9, 2010 | 12:22 PM
Haemon's Avatar
Depends on how long you've had your tunes, but you might look to see if your tuner would quickly change that one parameter for you for no additional, or a small charge. I'm assuming that you've got the ability to receive tunes via email... right?
I think he intends to revv his truck up in neutral/park to "show off" the full range of his exhaust, that's the only reason I can imagine a person wanting a higher revv limit in that case.
Old Jun 9, 2010 | 12:57 PM
Bingo, but not to anything extreme like 6500. Maybe 6000 at the very highest, but probably around 5500. I might have Bill tweak my 87 whenever I go back for a 93.
Old Jun 9, 2010 | 08:43 PM
ian51279's Avatar
So that extra 500 RPM qualifies as extreme huh?
Old Jun 9, 2010 | 09:25 PM
Yep, that little bit pushes it from high to EXTREME!
Old Jun 9, 2010 | 09:42 PM
Tumba's Avatar
What he said.
Old Jun 10, 2010 | 01:07 PM
Haemon's Avatar
Yep, your best off asking Bill if he would quickly just change that parameter on that one tune. I'd imagine this would take all of but 1 minute tops for a tuner to change 1 parameter to make their customer happy. It shouldn't effect anything else performance wise really to be able to revv your truck higher in Neutral/Park only anyhow, I just wouldn't pin it like that for a long period of time, other than that... have some fun with it
Old Jun 10, 2010 | 02:00 PM
It's my understanding the stock torque converter is only safe to 5400.
Old Jun 10, 2010 | 02:08 PM
Tumba's Avatar
Shrapnel much?
