diablosport predater u7153
it says its for the 99-03s but will it work on a 98? and if it does would it work on a 5 speed? and are they good setups? theres one in the local classifieds near me for half the price of one new,
is there any other way to check the pcm, i dont see any codes or nothing at all unless im looking at the wrong silver box and it looks like its wedge in there pretty good so taking it out looks like to much work lol, would scanning it with a code reader work?
some code readers may be able to display the calibration ID.
Passenger side dooor jam near hinges. There should be a white sticker with a code on it unless it has fallen off of your old truck.
Yes that is your base code. It is a good starting point. If you have been reflashed though it may be different. It is not the hex code though. You will need a programmer to pull the hex code if they need it.
ok noob question but whats a hex code, and how do i know if my ecu has been reflashed? and a actual programer or just a obd2 reader? im almost leaning towards that edge evoluton cts thing though, sounds like i can leave it hooked up to my truck and use it as a speedometer, as i cant figure out why my speedo no work
To simplify it the hex code is like the version of firmware your computer is running. You will need a programmer to read it. Speak with the vendor you are buying the programmer from and he will tell you what he needs.
