Belt squeal on Transmission shift
With my edge evo on level 3, when my transmission shifts during hard acceleration I hear a belt squeal type noise. What is that all about. Is that actually my belt squealing or is that a sign of transmission trouble?
You can do it.
Alls you need is a 3/8 rachet preferably with a long handle to put tension on the tensioner pulley to loosen up the old belt.
Follow the routing diagram on the radiator shroud.
You just need the rachette and NO sockets. The rachette drive goes into the square hole.
You can do it.
