Edge and NOS
Old Nov 4, 2009 | 06:08 PM
4x4wolf's Avatar
Edge and NOS
I'm green to this adjusting your programmer thing so bear with me. I was looking at ZEX safe shot nitrous kit it says the only additional part needed is a hand-held programmer to increase fuel enrichment. Could this be done with a Edge Evolution and if so under which category?
Old Nov 4, 2009 | 06:16 PM
Ftruck05's Avatar
Ummm.....I don't think so. Maybe something like this?
http://www.archcartpro.com/users/aut...&Vendor=&Year=
Old Nov 5, 2009 | 02:34 PM
JimmysotherFORD's Avatar
you need a custom tune, since you have an edge talk to ase mechanic or just go to powerhungryperformance.com and look into upgrading your edge into a gryphon.
Old Nov 5, 2009 | 02:47 PM
The Edge is for stock engines. Though it does not tend to lean out an engine, I would not use it with NOS, where it is imperative to never run lean. I speak from experience on that part! I would get a custom tune and have the programmer know you are going to be using NOS.
Old Nov 5, 2009 | 02:55 PM
i.ride.suzuki's Avatar
1.) Look into a better nitrous system with a TPS switch and adding a RPM activated window switch.
2.) A custom tuner should be able to create a 'nitrous tune' for you.
Old Nov 5, 2009 | 03:02 PM
Those interested in what air fuel ratio would need to be commanded by the PCM to get proper fueling here is the calculation.
300HP @ 12.6AFR
50HP Nitrous Increase
((300/350)*12.6)+((50/350)*7) = 11.8AFR
You would then convert to Lambda, 0.806.
Old Nov 5, 2009 | 04:26 PM
4x4wolf's Avatar
Thanks guys for the info
Old Nov 5, 2009 | 04:42 PM
blackedout50's Avatar
I saw a thing on tv that is a system that is capible of using nitrious as a add on to the edge programmer it was on the powerblock on spike a while ago will look i remember saying it was 400 safe hp will def have to find it now
Old Nov 5, 2009 | 04:47 PM
Found it
http://www.truckblog.com/videos/?c=tech
Click on edge f150 that is the video
nice lookin truck to
Old Nov 5, 2009 | 04:52 PM
4x4wolf's Avatar
Seen that one, edge only made that one they didn't mass produce it, such a shame
Old Nov 5, 2009 | 05:04 PM
Man I would love to have that but would prob blow my truck up
