Edge Evo problems?
Old Oct 27, 2009 | 07:58 AM
2007 Loaded FX4's Avatar
Edge Evo problems?
I have a Edge Evo in my 2007 F-150, when set to Level 3 performance and running on high octane fuel, the truck seems to be sluggish, it almost feels as if its "missing", like a issue with the sparkplugs or something. When im accelerating slowly it cant hold a steady RPM...anyone have any input???
Old Oct 27, 2009 | 09:45 AM
Is this something that developed over time or was it there when you first loaded in Level 3? If it was there at the first, have you ever downloaded any revisions? I would consider updating your Edge if you haven't.
Also, did you make any adjustments? What octane are you running?
Old Oct 27, 2009 | 05:59 PM
It seems to have just started... I am running 91 Octane gas. I returned the Evolution to stock a few times and still the problem persists. How can I download a revision? My Evolution is probably about 6 months old...
Old Oct 27, 2009 | 06:01 PM
If you have returned to stock and the problem is still there, then it has nothing to do with the Edge. Could be a throttle body problem, plugs, a dirty MAF, or dirty fuel filter. Could also be an injector problem.
Old Nov 1, 2009 | 06:58 PM
callmewhite's Avatar
i have had the same problem with the constant rpm change. i am lifted on 35s, CAI, and exhaust which i know i cannot adjust for until i send in my edge to get tuned. BUT the issue goes away at stock level and at level 1.
would tuning cause this to go away?
Old Jan 3, 2010 | 07:58 PM
highRize's Avatar
i have the same problem on level 3 and some times the whole truck will shake when driving or at a light. it goes away if i put it in neutral and rev it. it has only done this since i put the edge in. how and what udate should i download?
Old Jan 4, 2010 | 05:14 PM
#1wags's Avatar
Has anyone contacted Edge to see what's causing this problem?If they don't know there's a problem,they can't fix it.I just bought a Evolution but noticed the warning they had in the manual if you have any mods done like, CAI and aftermarket exhaust,and I have both on mine,so I emailed them as to what I need to do,so mine will work without any problems.So I haven't installed mine yet until I hear from them.I'll pass along any info.I get when I hear from them.
