got dyno tuned
got dyno tuned
i finally got my dyno tune done..only tuned for 87 octane..maybe could have made alittle more with 92 octane but oh well..we started at 160 and ended just shy of 175, and torque was 230 and ended at 233 but it was about 12ft/lbs more all through the rpm band once it started to drop off over stock.. i wish i had a print out of my base line to show my A/F with stock tune and no cats...it was a little leaner than whats in the pic but nothing to serious..i think it hit 14 but not sure and it started to lean up soon than the pic as well, around 4100rpm if i remember correct....here a link to the video
Are you running a V8? Any other mods? If its an 8 I'd have thought it would make bigger numbers. My 6 is pretty close in HP and just about the same Tq but I'm tuned for 94. But any gain over stock is a good thing.
yeah its a v8 4.6l out of a 02 mustang....at stock 4.6l on a 98 f150 dynos at about 140-145hp at the wheels..i have 4.56 gears, 35' tires, 75mm throttle body, pi heads, pi truck intake, underdrive pullies, afe stage 2 cai, no cats with a thrush welded muffler....think thats its nothing to serious..the truck fell flat after 4500-4800 rpm..it just couldn't breath anymore..i suppose the mustang manifold would breath better but would have less torque as well...so in my opinion coming in just shy of 175 is pretty good...you have to remember that i am probly loosing 110hp-150hp or more through drive train/tires etc and a tranny that has 280000km on it, and it never been rebuilt so i might be loosing some there as well
i might be pushing the max out of stock injectors..i had 22lbs (pink) injectors with me incase we maxed them out..no point in putting them in if i didn't need them
I know a quite a few Canadians that have pretty badass S197s that actually flew a tuner out there to tune it because of Techmotion's rep.
Techmotion.
your the first person that i have heard that doesn't like him
also i just found out that with the elevation change etc from calgary to where i am, there is about a 10% increase in hp so that would put me around the 190 at the wheels that even better..but next time the one shop here has there dyno days special i might get on there and see what it does here. just so i have a paper that says 190hp lol cause that better than 173hp lol..
wow..I didn't think you'd lose that much from the crank to the wheels, but factoring in the gears, tires and tired tranny, not bad #'s.
