engine swap
engine swap
I have a 2000 f-150 4x4 7700 GRW 5.4 with 10.25 rear end 3.73 gears Engine has ben knocking for 40000 miles mite be a rist pin, anyway what would be a good EASY swap for a engine. I do a lot of towing , would a 05 or 06 3v work or a lightning work better thanks Phil
There is a guy in Texas that sells adjustable cam gears for the 3v that disables the vct, he also has versions that allow a 3v engine to be put in a vehicle that originally had a 2v.
Get a set of those sprockets and a 2v to 3v swap is practically a bolt in, then he just needs a tune for the 3v w/o vct.
IDK what size injectors the old 2v 5.4's had but the 3v 5.4's have #24's, whoever writes your tune will need that info.
http://www.paschalperformance.com/3Valve.php
yours was 260 at the flywheel
yes the motor will bolt directly into your truck that with some additional bolt on's and you'll be all set, check out the supercharger/turbo charger threads and you'll see all kinds of links to MAD enterprise he's specalises in helping people make the swap
