PCM not responding after edge reprogramming.
Old Jul 16, 2009 | 10:34 AM
JimmysotherFORD's Avatar
so i get home from work and reprogram truck truck( its on level 3 and need to get gas, so im taking it down to trans only) and the programmer locks up, when it says programming complete, so now the PCM is not responding and the engine will turn over but not start. any info will help, right now edge is in a company meeting so no help there. oh yeah the error code that pops up on the edge screen is 150
Old Jul 16, 2009 | 11:11 AM
You are going to need edge's tech support for this problem!
Old Jul 16, 2009 | 12:16 PM
yes already talked with them everything is fine, i posted this because they were in some kind of company meeting, thank you for responding, and once again everything is fine.
Old Jul 16, 2009 | 12:47 PM
What did they have you do?
Old Jul 16, 2009 | 02:02 PM
the guy had me hook it up to fusion, and he downloaded my stock file checked it for corrupt files, and what not, sent it back to my edge, than set the truck back to stock, and he basically reset the edge. the problem was it wasn't getting enough voltage during programming, so i found out i need a new battery. not as bad as i thought it was going to be.
Old Jul 16, 2009 | 02:12 PM
Good deal. This information may help someone else out if they have the problem.
Old Jul 16, 2009 | 02:20 PM
Yes having a bad battery or finding out that you have one during the programming is a bad deal. The initial programming sequence sends a 18 volt signal to start the process.
A good idea in the future is to have everything off while programming.
Happy that edge was able to get it fixed for you!
Old Jul 16, 2009 | 05:20 PM
yeah i asked the tech guy if i could hook it up to a battery charger during reprogramming, and he said as long as your careful, cause too much can fry the OBDII cable or even the edge, so i did it with a 12V set to a 2amp deep cycle, and it worked fine. after all the other stuff.
Old Jul 16, 2009 | 07:15 PM
Sounds about right!
You had a good tech helping you!
Old Jul 17, 2009 | 12:09 AM
Fordahaulic's Avatar
I noticed that my DRL are on for the programming sequence, so I can see that being a problem if someones got a weak battery.
Old Jul 21, 2009 | 11:44 PM
jerrycranium's Avatar
Tuner
I have tried searching for the custom tuners talked about here on the forum but can not find what it is. Where do you buy them?
Old Jul 21, 2009 | 11:47 PM
Troyer Performance or VMP for the Xcal3 and www.powerhungryperformance.com for the Gryphon.
Old Jul 21, 2009 | 11:57 PM
Thanks Bluejay.
