performance upgrades
Old Jun 14, 2009 | 10:24 PM
Texan22's Avatar
Would a CAI new exhaust and edge programer be a good combination? Ive heard that combination would let the 4.6L keep up with mustangs. I have a 2008 f-150 stx 2wd 4.6L
Old Jun 14, 2009 | 10:28 PM
A41Billy's Avatar
I would say that's a damn good start! Although I have heard if you run a CAI you should get custom tunes. A Gryphon in your case.
Old Jun 14, 2009 | 10:32 PM
Fifty150's Avatar
For the money, custom tunes are the way to go. It's worth the difference.
Old Jun 14, 2009 | 10:41 PM
Texan22's Avatar
Yeah I know if I get the edge ill need it tuned. Want to get the exhaust and CAI then get the edge from PHP with the custom tunes. Any one got that combination?
Old Jun 14, 2009 | 11:29 PM
How extensive is your exhaust going to be?
If it's cat back, high flow cats, and or true duals with x-pipe it should be ok.
If you put LT headers on you need a tune though.
Good idea not to put cai until you have custom tunes on these trucks.
Just get the gryphon first.
Old Jun 14, 2009 | 11:43 PM
Texan22's Avatar
I just want a flowmaster dump. But shouldnt I get the cai and exhaust then the tuner. So I can just order the edge from PHP with the custom tunes to compensate for the cai and exhaust?
Old Jun 15, 2009 | 12:32 AM
rabbit hunter's Avatar
You can get a CAI before a tune, but its not suggested to "install" until you get your custom tunes programmed in. The exhaust is fine to go ahead and install. And from what ive read here your looking at about a 3 month wait for custom tunes. Which to me would not be a problem because a good product takes time.
Old Jun 15, 2009 | 10:09 AM
Texan22's Avatar
Thanks for the help
Old Jun 15, 2009 | 11:11 AM
i.ride.suzuki's Avatar
Stock 2005+ V6 mustang will still be faster.
The 4.6l 2v uses a tonsil style MAF sensor located in a housing, which is re-used. It does not need to be tuned, but can be if necessary.
Same as above.
Same as above.
Old Jun 15, 2009 | 01:55 PM
Veteran: Army
^^^ (just adding to the truth posted above) why does everyone confuses the 2 valve motors with the 3 valve motors??????
Old Jun 15, 2009 | 02:53 PM
Internet regurgitation.
Old Jun 15, 2009 | 11:24 PM
Texan22's Avatar
So........ Should I just get the edge evo with the stock tunes and put the CAI and exhaust on it and it should be fine? Or is my best bet to get the custom tunes? Sorry im new at this.
Old Jun 16, 2009 | 12:34 AM
Oops I completely missed the 4.6l part.
Old Jun 16, 2009 | 06:07 AM
Veteran: Army
you can get by without the custo tunes since you have a 2 valve motor but you can get better performance / mileage / driveability from custom tunes
Old Jun 16, 2009 | 06:17 AM
Veteran: Army
i miss 'em everynow and again myself, it happens
