2003 svt AEM brute force problems
Old Jun 5, 2009 | 08:52 AM
reaper999's Avatar
Put cold air system on, now I'm getting service engine light every so often.
Old Jun 5, 2009 | 11:37 AM
i.ride.suzuki's Avatar
Did you clear the KAM by disconnecting the battery during installation ?
Old Jun 5, 2009 | 11:55 AM
reaper999's Avatar
Yes, also used my diablo to check the code. Left bake running lean. Noticing black on exhaust tips.
Old Jun 5, 2009 | 02:35 PM
FordRacer2005's Avatar
Do you have a custom tune for this intake?
Old Jun 5, 2009 | 07:42 PM
reaper999's Avatar
Diablo's performance tune
Old Jun 5, 2009 | 11:09 PM
The tune needs to be set up for an intake. The tune you have is for a stock truck probably.
Old Jun 6, 2009 | 12:36 PM
reaper999's Avatar
Thank's, i'll give it a try.
Old Jun 6, 2009 | 02:14 PM
Veteran: Army
it's more than likely a dirty MAF or something else, the 2 valve's are different than the 3 valve motors
did you upgrade to a larger MAF???
reaper what's your fuel pressure at? any other mods???? whens the last time you changed plugs and cops??
Old Jun 7, 2009 | 08:23 PM
reaper999's Avatar
I'll clean the MAF. Truck is still all stock except flowmaster welded system.
I rarely drive it, I thought it was old fuel problem. I only have 20000 miles on it. Flushed the fuel system with Lucas cleaner.
