X3 Question
Old Apr 16, 2009 | 08:59 PM
sml175's Avatar
X3 Question
I will not have my custom tunes until June (so it looks). Can I go in and change the ratio and tire size via the option screens?
Old Apr 16, 2009 | 09:56 PM
07 Crew's Avatar
Yes you can, you need to figure out your tires rev's per mile and put that into the programmer. The easiest way to find it out is go to the maufacturers web site of your tires and it should tell you in the tires specs Even with the canned tunes you can adjust just about anything you want But all you do is go into options and change what you need to change.
Ricky
Old Apr 16, 2009 | 09:59 PM
sml175's Avatar
Thanks Rick. i will most likely do that after the weekend. 2 bass Ts this weekend. thanks again. Revs were 637/ BFg site.
