Best Mods, need help
Old Jan 11, 2009 | 03:51 PM
BigClifford's Avatar
Just curious on what some of the best mods are including cold air intake, chips/tuners, throttle bodies, or any other suggestions. All input is greatly appreciated. I want more power!!!!! I have a cousin who drives a chevy and thinks his is better so ya ... HELP, I wanna smoke his ***!!!
Old Jan 11, 2009 | 04:03 PM
hoss66's Avatar
supercharger
Old Jan 11, 2009 | 05:13 PM
dkgreyf150's Avatar
gryphon, gears, cold air intake, magnaflow, and if you have the money for the supercharger then yes go for it
Old Jan 11, 2009 | 05:35 PM
ParkM's Avatar
XCal3 w/ a 93 performance custom tune, full exhaust including long tube headers+X pipe+high flow cats+Magnaflow mufflers, at least 4.10 gear, Air Force One 3.5" Intake, U/d Pulleys, Electric Fans, that should be enough to get you started
Old Jan 12, 2009 | 08:50 PM
thanks, i just put shorty's on it the past 2 weekends, we still have to fix it this coming weekend because we can't get the collector to seal up or at least that is what we think it is, its leaking on the drivers side. i'm looking at putting on a cold air intake and looking at either a K&N 63 Series or an S&B, any thoughts on which is better? Also I'm looking at a programmer and am leaning between a superchip or edge evolution, which has everyone had better luck with?? Also, would it be better to put throttle body spacers or just put a new throttle body on??? This is what I'm starting with because I still want to get decent gas millage.
Old Jan 12, 2009 | 09:16 PM
ParkM's Avatar
The throttle body spacer is best used as a expensive paper-weight. Does nothing more than make a an annoying whistle. Whatever you get go with custom tuning, Gryphon or XCal3. Pulleys and electric fans will give you better gains rather than the throttle body.
