Error code help needed
Old Jan 10, 2009 | 02:23 PM
mt_b8's Avatar
Check engine light is on and I show two error codes. P0172 SYS TOO RICH 1, P0175 SYS TOO RICH 2. I am running an AF1 3.5" with a troyer xcal ii. What do I need to do?
Old Jan 10, 2009 | 04:37 PM
Drkharbinger's Avatar
Call/Email Troyer 1st.
Is it running a custom tune from Troyer?
If so, flash it back to stock, pull the battery cable off and let it sit a few minutes. Rehook the battery ensure everytihng is running fine and then re-flash it. If it is still an issue they probably need to update your strategy code.
Was your PCM ever re-flashed at the dealer? Maybe Mike or one of the other tuners will pop in and wow us with their skill.....
If not tuned, well it almost would have to be to run rich with the 3.5 AF1 so never mind.
Old Jan 10, 2009 | 04:52 PM
mt_b8's Avatar
Yes it is on a custom 89 octane tune but it has been tuned for over a year, I was just wondering if it might be an o2 sensor issue.
Old Jan 10, 2009 | 04:59 PM
Well, that is certainly a possiblity. How many miles are on them?
Old Jan 10, 2009 | 05:03 PM
mt_b8's Avatar
42,000
Old Jan 10, 2009 | 05:04 PM
mt_b8's Avatar
I would datalog but my wonderful ex wife took the notebook when she left
Old Jan 10, 2009 | 09:17 PM
You can set up the short and long term fuel trims in PID's and run it live. Empty road or with a passenger preferrably.
Edit....sorry, just saw the Xcal. Do you have the option to do live monitoring with the xcal?
Last edited by Drkharbinger; Jan 10, 2009 at 09:18 PM. Reason: dummy and didn't read.
Old Jan 10, 2009 | 09:36 PM
mt_b8's Avatar
I don't believe so
Old Jan 11, 2009 | 12:36 AM
I dunno, maybe you can clear the code. You could run it stock and see if it still throws it. If it still throws a rich code you will know there is a sensor issue for sure. I still recommend talking to Troyer monday.
Old Jan 11, 2009 | 10:11 AM
mt_b8's Avatar
Yeah, think I will try to get a hold of Mike Monday, Thanks bro.
Old Jan 12, 2009 | 12:45 PM
i.ride.suzuki's Avatar
The long term fuel trims have reached the calibrated limit, not a "sensor issue". The best thing to do is: clean air filter, clean MAF, replace HO2S if necessary, and clear KAM.
