OH YEA, Troyer Dyno Tune
Old Apr 17, 2008 | 08:42 PM
ThumperMX113's Avatar
Originally Posted by Gotts2BMe
You and OP of this thread were similarly modded with intake, exhaust, and a tune. You put down 241 to the rear wheels and the OP had 249 and both had the same RWTQ. I am going to go out on a limb and guess that the OP has 3.5 AF1 and magnaflow catback. The magnaflow flows better up top due to its straight through design which is where the other ~8rwhp is, assuming he went with the maggy
The size and weight of the tires does not matter on the dyno, much like gears. Do you know how much RWHP you gain by going from say 3.55's to say 4.88's? You actually gain 0 RWHP and that is because the output from the engine has not changed, you will gain a ton of speed but not more rwhp. Larger wheels and tires just work as the negative to that and don't effect your RWHP but slow you done a ton.
What are you talking about? We didn't put down the same dyno numbers. The OP said he put down 270 rwhp. I put down 240+ rwhp. I will say this though the 3.5" AF1 and the Magnaflow flow a lot better than a S&B intake and true duals with Flowmaster Mufflers.
Yes, tires do make a difference on the dyno. Why don't you give Justin or Mike a call and ask them? I can assure you that both will tell you when you're talking about a 37" tire, there's a big difference. We aren't talking about gears but you are correct as they do not effect numbers. The wheel/tires are ultimately the last thing of the vehicle before that power reaches the dyno. It's extra rotational weight, we're not talking about the diameter of the tire bu the weight. The weight is what's causing a loss.
Old Apr 17, 2008 | 08:50 PM
black07screw's Avatar
amen brotha haha
Old Apr 17, 2008 | 10:11 PM
Gotts2BMe's Avatar
Originally Posted by black07screw
I just have the dyn chart from yeaterday. I have other things like and exhaust and cold air intake and tune. Last time with my 33s and 20s I got 249 rwhp and 302 rwtq which is ok but my truck was being a biatch on the dyno. With the headers and coilpacks mike wipped her into shape on the dyn (at about 8pm at night) so Id say i got 25rwtq or so from the headers, they sound awesome and made the torque flat. The truck pulls hard now. Its awesome
When the OP was asked what he put down before the headers, he posted 249RWHP and 302RWTQ, where you put down 241RWHP and 302RWTQ. I know that the larger intake and straight through exhaust will flow better and that along with possible climate changes like temp, pressure, and humidity would make that 8rwhp difference. Either Justin at VMP does some amazing tunes to compensate for those massive 37's to put down similar numbers that Troyer put down with better supporting mods and smaller lighter tires, or I am right. I also just read a post that the OP has Efans and UDP's (Under drive pulley's) as well, Seen here ----> https://www.f150online.com/forums/sh...93&postcount=8
Old Apr 18, 2008 | 09:41 AM
I must of missed the part about the 249 rwhp and 302 rwtq. I apologize for that. Well, I guess Justin just writes an amazing tune.
Why not just call Justin or Mike and find out for yourself?
Old Apr 18, 2008 | 11:36 PM
Gotts2BMe's Avatar
Because I already had that discussion with "vitviper" (a tuner) over at bamachips a couple years ago
Old Apr 19, 2008 | 12:01 AM
Think about it. What you're saying makes zero sense. How would rotational mass not effect rwhp. The crank hp would be the same but the rwhp is going to be different. Those axles, gears, driveshaft, transmission all have to spin more weight with bigger tires which would reduce rwhp. I'm going to have to agree to disagree with you on this one because it seems like you're stuck in your belief as I am (.. and others).
Old Apr 19, 2008 | 12:39 AM
Gotts2BMe's Avatar
trust me I was in the same boat as you. I put down 140 whp with my escort zx2 that had some heavy *** 17s on it and was saying I would probably put down 145 whp with smaller tires until he came in and shut me down and told me I would gain about .1 whp on the dyno with some light weight 15s. I fought and fought and fought until he laid down his thousands of hours of dyno time card and trumped everything I had....
Old Apr 19, 2008 | 12:55 AM
Of course the difference between a 17" wheel and 15" is going to be minuscule. I've talked to Justin about this before and there is a loss. Say on my Mustang, my 20s vs factory wheels/tires is a loss of about 2-3 rwhp. However HEAVY 37" tires and HEAVY 20x10 wheels are going to make a big difference. I'd like to know how you believe that it wouldn't effect the numbers though? Do you have a reason?
Old Apr 19, 2008 | 01:22 AM
Gotts2BMe's Avatar
The difference was about 10lbs per wheel on a 2500lb car that came from the factory with 130 crank hp.
If it really is the case that those 20s were really holding your truck back that much than I would have to say that vmp puts down a LOT more power to the ground then Troyer does (assuming they both use the same type of dyno, mustang or dyno jet). Both of them are relatively close to the same elevation but the warmer temperatures and higher humidity in Florida would hurt his dyno numbers.
I am going to answer your question with a question. Do you think that your 37s vs 33s, S&B vs 3.5 AF1, and magnaflow vs fartmaster only equates to 8whp and the SAME torque with your theory?
Old Apr 19, 2008 | 02:12 AM
tj03f150's Avatar
Well basically with mikes stage 3 kit with 33.5 x 12.5 " tires with 20s I put down about 270 rwhp and 334 rwtq.
wow very nice!!
is this a 4.6l or a 5.4l? either way thats really really good.
Thats just about what my truck makes and urs is N/A!
and yeah, tire size and stuff does matter.
look at this guys truck, very nice truck - https://www.f150online.com/forums/sh...d.php?t=329403 but his tires and all that rob his dyno numbers big time.
Old Apr 19, 2008 | 10:26 AM
10 lbs per wheel so that'd be a total of 20 lbs. I'd have an increase of 20 lbs per wheel, at least. Do you realize that no one truck is alike? The 8 rwhp could be easily made up between a good motor and bad motor from the factory. There are differences of 10+ rwhp from the factory. You cannot just compare two different trucks on two different dynos on two different days. I guess that just shows that Justin's tunes are that good. If you can show me how you think more weight won't hold back those wheels from putting down more power. I'll say you're right and I was wrong until than I'm done with this thread because it's becoming simply a waste of time. You state your case like a politician.
Old Apr 19, 2008 | 03:29 PM
jpdadeo's Avatar
size matters
Old Apr 19, 2008 | 05:43 PM
Originally Posted by jpdadeo
size matters
That's what she said ... Seriously, this guy is in denial.
Old Apr 21, 2008 | 09:09 AM
kdds05screw's Avatar
........ Yea neil did the install those headers are bad a$$ and really flatened out the torque curve. How are you liking your gears??? Thats whats probably next
Cool, the long tubes are definately the next ( and final ) perf mod here. As far as gears, this thing launches off line now and in all gears, truck operates more within the power band. Next to the tuner, this is the best 'seat of the pants' mod I've done. imo, well worth it. Gears for offline and keeping truck more in powerband, and intake/tuner combo ( and headers soon ) to give it the set of ***** that Ford forgot. I'm staying with the 33" tire size. ( 33.6 " actually ). Not too bad on highways, speed limit is 55 basically everywhere here but on the turnpike and a few other state routes where it is 65. You would have to run up to 35" tires if you were a regular 80mph traveler as it may be a bit much now for some.
Old Apr 21, 2008 | 08:51 PM
JeremyGSU's Avatar
You realize the size of the tires and weight of them don't actually make a difference on the dyno numbers. You might add about .1 rwhp with the 18's....
Eh...when I went from the factory 18's to the factory 20's it slowed my truck down noticeably driving around. It makes no sense why you wouldn't lose hp on the dyno when it takes a good bit more power to turn a heavier wheel.
