Edge adjustment questions?
Old Mar 22, 2008 | 10:21 PM
jasonkola's Avatar
well I have been playing with level 2 custom adjustments. I was curious what adjustments I could make that would make it no longer tow safe. I am not sure the difference between the performance tune (not tow safe) and the level 2 tow safe program. and also I was looking at adjusting my standard shift points I wanted to adjust them down closer to stock or just above to improve gas milage. It only gave me a choice between -1 and -2. I Don't quite understand this adjustment. would -1 or -2 be closer to stock. I set it at -1 which still seems a little high. but I did not want it to be below stock so I did not try -2. I would prefer just above stock a little. I suppose this would be a question for bill. I hope he is feeling better.
Old Mar 26, 2008 | 08:31 PM
jasonkola's Avatar
bump
Old Mar 26, 2008 | 11:41 PM
king ranch's Avatar
read manual it will explain alot on std shifting points if u go up then it makes the truck shift later and runout the rpms higher to get better performance and u wont get as good gas mileage if you go neg's then it downshifts quicker and loose performance but gain gas mileage
