XCal2 Problem ?
Old Mar 8, 2008 | 10:21 PM
UKSVT's Avatar
XCal2 Problem ?
Just got a new XCal2 with a custom tune on it but think I may have
a problem. If I plug it in to my Lightning nothing happens it doesn't
light up with ignition off or on. The only way I can get it to come on
is by plugging the USB cable into my laptop. It comes on o.k. then I can read
the fault codes etc. Should it be like that ?
Cheers, Col
Old Mar 8, 2008 | 11:25 PM
ONELOWF's Avatar
I don't think so. Mine comes on when it's plugged into the OBD2 alone.
Old Mar 8, 2008 | 11:29 PM
Racing2Fast's Avatar
Check you Cigarette Lighter if you have one, and see if it still get's hot. A while back I tried to use a Scan Tool, and had the same issue. Ended up being a blown fuse that controlled the Cig. Lighter, and the OBDII Port.
I would bet it's a fuse... Esp. since the unit powers up when connected to the computer.
Give that a shot and see what happens!
Tom
Old Mar 8, 2008 | 11:32 PM
ThumperMX113's Avatar
I agree with Racing2Fast, otherwise it's a fault device. I'd contact SCT after checking your fuses to see what they say. Seeing how it comes up with your laptop reinforces the idea that it's a blown fuse, etc.
Old Mar 9, 2008 | 12:02 AM
UKSVT's Avatar
Yep never thought about a fuse, I'll give that a try.
thanks, Col
Old Mar 9, 2008 | 04:49 PM
thanks, Col
What did you find out? Was it a fuse, or faulty Xcal? Im interested to know!!
Old Mar 13, 2008 | 05:42 PM
UKSVT's Avatar
Yep turned out to be the fuse after all. Number 3 in the fuse box below
the steering wheel. Got another problem Today, fitted a 6lb pulley and
a 90mm Maf, air filter and TR6 plugs. Uploaded my tune in the Xcal from
LFP but when I took it out it didn't want to go beyond 3500 revs, sounded
like it was breaking down. If I creep up the revs slowly it will go to the redline
but any sudden acceleration makes it break down. Throwing code P0107 MAP
Cir low, which I believe is low voltage result from MAP sensor located beside
the brake servo ? Not sure what to do about it though.
Col
Old Mar 13, 2008 | 06:27 PM
Glad it was just the fuse, and not an issue with the Tuner.
As far as the other issues your having. Im afraid I cant help with that. Im not familiar with supercharged motors, and the tunes, they use.
I would rec. talking with the guys you got the tune from and make sure it's not an issue with anything they did. Other than that Im lost as well!
