Evo V3.xx.xx and Edge FUSION
Hopefully we can get this as a sticky.
For Evolution users with a Version# of E3.xx.xx (ie. E3.08.11, E3.22.28, etc)...
ABSOLUTELY DO NOT USE FUSION to update your unit. You will be left with a blank screen and a disabled unit. You can find your version number on the sticker on the back/bottom of the unit or in the Version Info menu.
Fusion currently only supports v4 and later versions. If you go to the [Diagnostics] -> [Version Info] screen, you should see something like...
First screen:
Model: EEF2400
Bootloader: 2.60.0
Firmware: 2.50.4482
Calibration: 1.0.4430
Hardware: 2
Serial #: 1011500
Second Screen:
Last Programmed To:
ECM: RXAQ5B4.HEX
If you see something similar to the above, particularly the separate firmware and calibration versions, then you can use FUSION.
Once again, if you see a version of E3.xx.xx, DO NOT USE FUSION.
Of course, if you are reading this because you already bombed the unit using Fusion then you'll need direct assistance.
Bill
First screen:
Model: EEF2400
Bootloader: 2.60.0
Firmware: 2.50.4482
Hardware: 2
Serial #: 1011500
Second Screen:
Last Programmed To:
ECM: RXAQ5B4.HEX
Bill
here's an email i got in answer to the Lightning/Fusion question.
On Jan 23, 2008 12:26 PM, Edge Tech <tech@edgeproducts.com> wrote:
Ron,
Fusion is the newest software that is replacing Lightning, so from now on we recommend you use Fusion, UNLESS! the version on your Evo is something like this (i.e. E3.25.22) but if the version is a solid number like 2,6,7, or 10 something along those lines, then use Fusion. the version is located on the bottom of the unit on the silver sticker. thanks JRS
Edge Products Technical Support
1080 S. Depot Drive
Ogden, UT 84404
Toll Free: 888-360-3343
Local: 801-476-3343
Tech Fax: 801-337-2198
Email: tech@edgeproducts.com
www.edgeproducts.com
*** Due to the large volume of e-mail we receive, PLEASE include previous e-mails when responding. This will allow us to read the complete dialogue in one message and will result in quicker responses. Thanks! ***
Ron,
1080 S. Depot Drive
Ogden, UT 84404
Local: 801-476-3343
