Edge tire sizing
Edge tire sizing
with the edge the tire sizing says to go in small steps and over time soo what are the steps that should be taken and what are to large of jumps im trying to go from stockers to 34.80
also will changing the tire size fix the dash speedo??
thanks matt
thanks matt
thanks matt
thanks matt
I just replaced my stock 275/65R18 on my FX4 to a much bigger 35/13.5R20.
I didn't have any problem setting it to the correct wheel size with the EDGE. At 35" the EDGE size is 2792mm.
Yes, the EDGE reprograms the PCM and changes the speedometer to the corrected speed for the new tires.
Schmidtty
Schmidtty
That will get you close, but if you want to be as accurate as possible, don't rely on the manufacturer's spec'd size. Chalk your tire and mark your driveway so you can measure one full revolution. (Do it a few times, to be sure) This gives you an accurate circumference and accounts for the 3-5% "squish" where the tire is knocked out of round.
1" = 25.4mm
1" = 25.4mm
The "small steps" don't really apply to tire size. Right is right.
Use the method I described above to figure the size. Do it three times and take the average if they're all close.
...if you want to be as accurate as possible, don't rely on the manufacturer's spec'd size. Chalk your tire and mark your driveway so you can measure one full revolution. (Do it a few times, to be sure) This gives you an accurate circumference and accounts for the 3-5% "squish" where the tire is knocked out of round.
1" = 25.4mm
1" = 25.4mm
