Edge & Transmission
Old Jan 31, 2008 | 02:54 PM
Justin FX4's Avatar
Edge & Transmission
I have a little issue with my edge.
i have it set on level 2 and the only adjustments is my timing and it is set at
+1, when my cruise control is set and i go down a steep hill my RPM's drop and well below normal and it has a little jerk like it is wanting to have a hard engine break.
what would cause that or is it normal.
Old Jan 31, 2008 | 03:03 PM
beckerjs's Avatar
if you just put it in give it a week to get used to your driving habits
Old Jan 31, 2008 | 03:04 PM
Just curious, why do you have your timing bumped? Are you running 89 or sea level? As to the jerk, it is probably the torque converter and that is somewhat normal.
Old Jan 31, 2008 | 03:24 PM
Justin FX4's Avatar
Yea i am running 87 octane fuel here in nebraska. with the timing bumped up a little bit it runs a little smother during idle.
I have had it for a week now and i was looking at the options and i set the speed limiter to 125 instead of 100 and that is when i noticed it at first. Then i changed it back and id dosent to it as bad but it sill does it.
Old Jan 31, 2008 | 03:36 PM
2005lariatky's Avatar
I dont see why the speed limiter would have anything to do with it.
Old Jan 31, 2008 | 07:57 PM
mbogosia's Avatar
Registered User
Mine can be a bit quirky on my 07. For instance when I changed my standard shift points to +1 my truck acted really weird. I also can't mess with some of the other options. Its almost like my truck can only handle so many changes to the PCM at once.
Old Jan 31, 2008 | 08:45 PM
ThumperMX113's Avatar
Well, did it have this problem stock?
Old Feb 1, 2008 | 10:00 AM
Justin FX4's Avatar
No it didnt have this problem stock,
it started on tuesday. i think that i have to mess with it a little and get my settings set just right.
