Towing on level 3 edge???
Old Jan 28, 2008 | 11:45 PM
twintips_17's Avatar
SO i have read and posted about towing on level 3 with an edge. I know that it hurts your Auto tranny from the shift points and firmness. I know that it akes your EGT's run high and burns up your cats. I have a 5spd and no cats. So does towing in level 3 still hurt my engine?
Old Jan 29, 2008 | 04:48 AM
Tornadom's Avatar
Well, you obviously won't have a problem with your cats and transmission, but the EGTs ought to still be a concern. How heavy are you towing, and in what terrain? I guess it is possible to do, but why not click the buton back to towing?
Old Feb 8, 2008 | 02:40 AM
ASEMechanic's Avatar
Level 2 is slightly richer and has slightly less timing to accomodate towing situations. I don't recommend towing anything heavier than a small trailer (boat or ATV type) on level 3.
Bill
Old Feb 8, 2008 | 10:29 AM
2005lariatky's Avatar
Bill,
Can you back down the timing advance and WOT and run 87 or 89-91 octane fuel? I know this doesnt apply to towing but just curious.
Sorry for the thread hi-jack.
Old Feb 8, 2008 | 11:19 AM
Yes... sort of. The timing advance option changes the whole table by x degrees. So while it would effectively reduce timing in the high-load regions for the timing table, it would also reduce cruise timing which would hurt fuel economy. The Level 2 timing tables take this into consideration and have lower timing in the mid to heavy throttle range to prevent detonation while still maintaining good cruise characteristics.
Hope this helps.
Bill
Old Feb 9, 2008 | 03:56 PM
Zaairman's Avatar
I towed my 16' boat everywhere with my F-150 on Level 3. Towed it like a dream.
