Aftermarket gauges
Old Jan 2, 2008 | 08:40 PM
monk36c's Avatar
Aftermarket gauges
Im llookin to put in aftermarket gauges in my 99 f150. Trying to not to spend a lot, just something to look good. Any ideas on what 3? I was thinking transmission temp, engine temp, and something else.. also, any ideas of pillars and where i should get them?
Help?
Old Jan 2, 2008 | 09:42 PM
Veteran: Army
look on the lightning sites, the same pillar/wheel pods will fit your truck
Old Jan 2, 2008 | 09:48 PM
twintips_17's Avatar
Help?
Have you seen the dashhawk??? Look at that. Might be a bit more..
http://cgi.ebay.com/ebaymotors/MSD-d...QQcmdZViewItem
Heres a new one on ebay cheap. ITs the same thing as the edge just no power gains. They look sweet!!!
Old Jan 2, 2008 | 09:53 PM
monk36c's Avatar
Which sites? I went from a Jeep to f150 recently, so I'm not familiar with the sites yet.
Old Jan 2, 2008 | 10:04 PM
Veteran: Army
http://www.buyfordracing.com/shop/index.php?cPath=22
this is the guage I put on my '01 F-150
here's some more guage pods for you
http://www.egauges.com/vdo_acce.asp?..._2003&Manf=All
http://www.lightningforceperformance...ack-p-729.html
http://www.rpmoutlet.com/lightning.htm
there's a few more for you
Old Jan 2, 2008 | 10:24 PM
ScottFF00's Avatar
Take a look at the scangauge II.
http://scangauge.com/
Do a search on here. A lot of guys have the scangauge or the dashhawk and love them. I guess its all about what you are looking for.
Old Jan 3, 2008 | 04:52 PM
Mickey_shouse's Avatar
trans/water temp, fuel pressure and wideband would be three i would start with.
the only difference between the trans temp and water temp is the word trans or water. you can just get two senders and a 3 position switch and go back and forth between the two. this is what i did with my lightning. aem has a good wideband that isnt too pricey. im going to add a fuel pressure gauge soon as i have trans/water temp, wideband , and boost guage in a lotek pillar pod.
Old Jan 3, 2008 | 08:32 PM
monk36c's Avatar
I went ahead and went with autometer z series, trans temp and oil temp on a 2 pod pillar. Thanks for all the help!
Old Jan 4, 2008 | 03:49 PM
go to www.timskelton.com and look for the guage install, helps alot . i used the pointers when i did my gauges.
