edge Q
Old Nov 13, 2007 | 01:34 PM
FORD-country's Avatar
edge Q
well im set to have the edge in later today. i wanted to try level 3 right away for power increase but still have half a tank of 87 octane. just wondering which level i could run on at least for a little. do you think i can just add half a tank of 93 octane and run it? or will that be bad?
Old Nov 13, 2007 | 01:41 PM
That would be bad. Just run level 2 till you can get most of a tank of 93. That way, you will be able to compare the difference. Just go ahead and use the same settings for everything except the timing. Be sure and bump the timing when you go to level 3 as it is programmed for 91.
Old Nov 13, 2007 | 01:45 PM
ok cool ill just run level 2 for now. any custom settings i should change?i have 6in lift with 35's. so i guess ill just change tire size. anything else?
Old Nov 13, 2007 | 01:50 PM
mgp32's Avatar
gears
Old Nov 13, 2007 | 01:52 PM
why would i need to change the gears? i have factory gears
Old Nov 13, 2007 | 01:55 PM
I like firmer shifts. Do an advanced search on "Edge Settings" and you should get lots of guys settings. You want to be sure and check to see what gears your unit defaults to and change the ratio if yours are different.
Been so long since I set mine I think I have the following:
Shift Pressure 1-2= +12 2-3= =12 3-4= +9
Shift Points 1-2=5250 2-3=5250 3-4=4800
Max RPMs 5650
Max speed 110
then when I go to level 3, same as above, and:
Timing +1.0 or +1.5
WOT Fuel +1.5
Oh, and I bump the idle up to 700 to 800.
Old Nov 13, 2007 | 01:58 PM
ok cool. thanks for the info. im goin to go search for some peoples settings for their edge.
