edge elevation and timing
Old Nov 4, 2007 | 08:57 PM
jonamond's Avatar
how high do you have to be to safely start bumping up your timing every .5 degres...
im 600ft above sea level and running lvl 2. 87 oct.. is there any adjustments i can do?
Old Nov 4, 2007 | 09:00 PM
MGDfan's Avatar
I'm even higher than you, and I don't apply any corrections - it's ain't high enough to matter.
Old Nov 4, 2007 | 09:09 PM
jonamond's Avatar
lol Thanks again
Old Nov 4, 2007 | 09:26 PM
MGDfan's Avatar
lol Thanks again
Hehe.... NP bud. I'm approx 40-ish miles southwest of you on Hammer Mountain, lol - we is HIGH !
MGD
Old Nov 5, 2007 | 02:11 PM
BSL's Avatar
BSL
I was told every 3k ft you can bump the timing up .5, I'm running +1 in Golden, CO which is right around 5900 with no problems
Old Nov 5, 2007 | 08:38 PM
Silverfish's Avatar
1 degree for every 2500 feet above sea level.
Here is a link from Bill: https://www.f150online.com/forums/sh...95#post2017095
Originally Posted by ASEMechanic
Roughly 1 degree per 2 octane.
Level 3 (basically 91 octane tune) running 93 = +1 deg.
Level 2 (basically 87 octane tune) running 93 = +3 deg.
Level 3 running 100/101 = +5 deg. (This is for the rich guys!)
These are ideal values at sea level. At altitude, you should be able to add another degree per 2500 ft.
5000 ft. = +2 deg.
Just so you know, I can run level 3, +3 deg at 4500 ft with 91 octane. 4 to 4.5 degrees gets me a nice rattle on heavy throttle tip-in (low RPM throttle stomp) but actually drives quite nicely on the highway giving me another +.25 to +.5 MPG at 70 MPH versus +3 degrees timing.
I hope this helps a little.
Bill
