pull fuse when loading SCT tune?
I thought i remembered troyer recomending to pull a fuse when loading a tune using the XCAL2. Was it the maxi 19 fuse? I cant remember - just seeing if anybody knew real quick -
thanks!
thanks!
thanks!
thanks!
If you don't have an Owner Guide, you can download one from here: http://www.motorcraftservice.com/vdi...&menuIndex1=18
EDIT - ok, had a look at the 1998 guide - position #19 - Fuel Pump Relay - 20 amp (page 140 in the guide)
Last edited by MGDfan; Oct 16, 2007 at 12:20 PM. Reason: wrong manual page -should read page 140 lol
Thank you MGDFan!
I appreciate you taking the time to look that up i just wasn't sure which one to even look up. thank you very much! I dont wanna mess anything up ya know
what's the difference if you pull a fuse or not???? does it hurt the tune changes???
Originally Posted by Darnell@Hypertech
From what I've seen most times you can get away with not pulling fuses. However most times when someone is having trouble programming, simply pulling a certain fuse can remedy the problem. The reason behind this is things like a fuel pump or satellite radio may activate and cause a drop in voltage large enough to interrupt the tuning process.
Apart from all of that - a fully charged battery and elimination of any non-essential loads by pulling fuses (eg. amps, lights, fans etc) is a very good practice to follow - you need to ensure that supply rail has adequate voltage - flashing is a relatively demanding process.
bubba
