Which part is my computer code???
Old Oct 10, 2007 | 06:35 PM
cdiddy4224's Avatar
ok i know its 3 letters followed by a number. I got my xcal2 today from member "smalltownspeed"(he shipped extrmely fast, very honest) and i plugged it into my truck. I got this:
Strat=ODAL1EW
DTC=P1000
now i know the computer code is only 4 characters, so would my code be DAL1???
Old Oct 10, 2007 | 06:43 PM
INFireRedF150's Avatar
Strat=ODAL1EW
DTC=P1000
Open ur passenger side door, front if you have a supercab or supercrew, and look on the body column normally covered by a closed truck door, should see a white sticker with this 4-character code and compare to what your xcal2 is telling you. Mine is LGA1 for example, and it is on that sticker.
cdiddy4224's Avatar
i dont have a sticker there anymore, it has vanished
Old Oct 10, 2007 | 06:48 PM
Found a website that said also check under the hood, maybe something there along with the belt diagram or vacuum diagram stickers. I pulled my PCM to install a chip, but I cant remember now if my PCM itself also had a sticker on it. Worse case, your dealer should know, or if bought used from a non-Ford lot, next time you take it in, see if they would put their scanner on the OBD II port and tell you. HTH
Follow-up: Just went to SCT's website and it does show a Ford PCM with code stickers on it, so if you can get to your PCM and see a sticker, especially without removing the PCM, that should have your PCM code.
Old Oct 10, 2007 | 07:02 PM
cdiddy4224's Avatar
i saw that on their site also...says my pcm is under the dash on the passenger side...i looked and cant find jack
Old Oct 10, 2007 | 07:05 PM
it is under and to the right of your glove box, back underneath the passenger dash. Get under there, look along your interior body wall, and look for a dull silverish box mounted to that wall. You will know you are looking at the right wall when the wall color matches your exterior paint. You can also look under your hood, on the passenger side for a big multi-wire harness going into your firewall. That is the harness going to your PCM. Look for such between your battery and the firewall. Cant miss it. Your 2002 should be virtually identical to my 2003.
Old Oct 10, 2007 | 07:14 PM
cdiddy4224's Avatar
your dead on...there was a black tab over the pcm code, so i popped that off and there it is!!!! Time to place my custom tunes order!!!!
Thing is the pcm code on the box does even come close to what the Xcal2 showed
Strat=ODAL1EW
and my pcm code is BWJ2
Old Oct 10, 2007 | 07:16 PM
Strat=ODAL1EW
Not sure what that Strat variable stands for. Might not even be related to your PCM code. I did a search for such but no returns. Does your XCal2 manual have a section on variable definitions?
Old Oct 10, 2007 | 07:18 PM
06darkstone's Avatar
Strat=ODAL1EW
knowing the 7 digit strategy and the pcm code is better information and will help with the tune..give them both
cdiddy4224's Avatar
id have to check through it...i read the sheet that troyer sends out and i followed its directions where it said the pcm code was. Ill do a bit more reading
Old Oct 10, 2007 | 07:40 PM
cdiddy4224's Avatar
the strategy code and pcm code arent going to have the same info are they? For example my PCm code isnt supposed to be located with the strategy code is it?
