EDGE ???'s
Old Aug 15, 2007 | 09:50 PM
polpilot's Avatar
EDGE ???'s
i just got my edge yesterday and i LOVE it 150% better then the Hypertech i had. the only thing is i cant change the tire size. it says it not available for my truck??? will a simple update alow me to change it? the tires i have now are a little smaller then stock.
Also can some of you post what costem tunes your running on your 1997-2003 f150s with the 4.6...
Old Aug 15, 2007 | 09:58 PM
hivoltagefx4's Avatar
If your tire size is not listed, you will have to enter it manually. The is a calculation method for this. You should find it in the manual.
Old Aug 15, 2007 | 10:01 PM
polpilot's Avatar
No the edge wont even let me do it that way. idk whats up?
Old Aug 15, 2007 | 10:06 PM
polpilot's Avatar
EDIT----- oops double post
Old Aug 16, 2007 | 11:08 AM
F150FXOnline's Avatar
polpilot thats odd if it wont manually let you change it through the custom settings. I would first reset everything back to stock unplug it and make sure its plugged in good. Then try again, will it let you go through and change any other options through custom settings like the gears ect?? if still no luck I would reflash the unit and or call Edge. Just curious were did you buy your unit from?
Good Luck!
