what performance chip to use
Old Aug 15, 2007 | 03:05 PM
fslopez2's Avatar
I would like to add some hp and torque to my 2001 F150 4.2l V6. What can I do besides a superchip, which by the way they no longer do them for this model? I want to keep the cost down so any ideas would be helpful. I have added a K&N filter so far. Thanks!!
Old Aug 15, 2007 | 03:58 PM
denis12340's Avatar
I have the bully dog for my 5.4 and to tell you the truth it didnt make all that much difference.I have it set on the second setting it does run smother i think i payed about 350.00
Old Aug 15, 2007 | 08:25 PM
MGDfan's Avatar
Hi.
You have choices.... http://www.troyerperformance.com/cgi...uning%3BFoMoCo
Give them a call to discuss. I would choose a flash programmer (e.g Xcal2) over a chip; much more flexible.
TP can custom-tune your truck, no problem.
Good luck.
Bubba
Old Aug 15, 2007 | 11:16 PM
fslopez2's Avatar
Is this an expensive way to get what I need? I know the superchip costs 233.00.
Old Aug 16, 2007 | 07:15 AM
MGDfan's Avatar
Yes, it's more.
However, the Superchip holds only one tune - and you must use 91 oct or more. To update the tune, you need to send it back in.
Flash devices hold several tunes - and some (as is the case with the Xcal2 f'rinstance) can be updated online.
Finally - consider that custom tuning will net you significantly more gains than any 'canned' tune.
As I said - just call them. Their website also still lists the #1100 single tune chip - so they may still be able to supply one, if you insist on this option to save $.
BTW - how many more threads are you gonna start asking the same question??? LOL!
Bubba
Old Aug 16, 2007 | 09:48 PM
ScrewedUPF150's Avatar
6600 chip
The 6600 chip holds 3 tunes that u can interchange as well as the stock tune. I have it and it works well. Only chip I would go with. Next step up is a tuner.
