Interior paint codes inside
Old Aug 6, 2007 | 05:33 PM
051fdrof's Avatar
For all of you Edge pod painters.. Here's a link to a pdf containing the 2005 ford paint codes: paint codes (pages 3 &4)
I don't think all of the part numbers are current, but I Googled the Dark Flint code and it took me to tsetruckstuff.com, where they had the replacement number listed.
I punched that number into fordparts.com just for the heck of it and it appears to be valid.
Once I'm sure I have the right color, I'm going to place the order. On the door sticker, under the INT TR field, there's a 2-digit code. I'm pretty sure that the second character is the one that gets cross-referenced in the chart. For me that's an E, which is a combination of black and 2 Flints, so that makes sense.
Hope this helps.
Old Aug 6, 2007 | 07:00 PM
Toolcrib's Avatar
None of the paint codes that you posted will match the warm steel colour that is the main colour in the backbone of the dash,on the 2004 and up f 150 You have to have it mixed,as I believe Quintin said in the past, it is an oddball paint formulation.Check the link I posted in the Edge pod paint Question.The paint codes in the Ford guide that you posted ,will help you get the paint for the glovebox,interior doors, dome above instrument cluster, etc , but not for the main dash.I have had to Paint my dash,so I know from Trial and Error.
Old Aug 7, 2007 | 11:27 AM
051fdrof's Avatar
I want to paint the pod to match my dash trim color, where the vents are located. Is this "warm steel" color that you're referring to? I don't have an FX4 or Lariat, and I'm not trying to match the light grey color on the main portion of the dash. I do have two different dark grey colors on my door panels. Are you saying that neither of them are the same color as my dash trim?
Old Aug 7, 2007 | 11:53 AM
05RedFX4's Avatar
That "warm steel" color only comes on fx4's and lariats. XLT's and below have either the gray or tan dash.
