Edge question about idle
Old Aug 2, 2007 | 09:28 PM
je3169's Avatar
Guys this is what i got i got my edge on friday and programed towing and everything works great today i filled up with 93 and changed it to performance and if i am sitting at a light or in the driveway and it is in drive i get pulse you can see the tach moving about 200 rpm and hear the engine so i set it back to tow and all is fine anybody have this problem. any input would be great the only thing i change is my tire size and gearing.and i had about 3 gal of mix 93/87 in the tank when i filled up
TIA
John
Old Aug 2, 2007 | 10:18 PM
twintips_17's Avatar
Did you bump the timing to match your 93 octane???????
Did you do a custom tune?
If so what were your numbers?
I boubt if you have as to the fact you have to tune your vehicle 4 times to be able to but i thought i would ask.
Help me.... Help you
Old Aug 2, 2007 | 10:34 PM
je3169's Avatar
gearing to 3.55
tires to 2540
everything else is what edge set it at i did try to jump up the timing to 1 but it did not help so i set the timing back to 0 ( I have these settings on power level 2 and everything is fine for some reason when i go to power level 3 i get a pulse or a serge when at a light with the truck in gear.
Old Aug 2, 2007 | 10:38 PM
Originally Posted by je3169
gearing to 3.55
tires to 2540
If you got time try this. Go and set the edge to level 2 but bump the timing up 2.5. Are you sure you got good gas. Who did you buy it from. Positive its 93 octane? Try level 2 with the timnig adjusted and let me know. Then if it works i would try and bump the timing by 1.5 or 2 with level 3 just to see if it affects anyhting.
Old Aug 2, 2007 | 10:54 PM
je3169's Avatar
I put mobil gas 93 I will go try it now
Old Aug 2, 2007 | 10:58 PM
Ok hit me back. Ill be on here for a while.
Old Aug 2, 2007 | 11:23 PM
je3169's Avatar
ok i set it at level 2 and set the timing at 2.50 and it did the same thing (surge) changed it back to 0 and it was fine so i tryed level 3 again and set my gears at 3.55 my tires at 2540 and left timing at 0 and is is running smooth now i am at work now so i could not drive it my cooling temp was 188 so i will see how it drives on the way home in the morning.
John
Old Aug 2, 2007 | 11:52 PM
John
You got some low end gas. I would set it for level three and leave it untell your empty and then fill up again and try to advace the timeing.
Old Aug 3, 2007 | 12:08 AM
Adam06FX4's Avatar
Registered User
make sure your edge is up to date also
Old Aug 3, 2007 | 08:24 AM
F150FXOnline's Avatar
je3169 youd shouldnt be having that problem at lvl3 at the stock performance lvl. I would either leave it at lvl2 since it runs ok at that lvl till you get low on gas and refill at a differant gas station and try lvl3 again.
Also like Adam06FX4 said check you updates. Also for kicks set everything back to default unplug "everything" and start over.
Also I wouldnt hessaite to call Edge for help. Also dont e-mail them they dont reply back to youll need to call them.
Good Luck and keep us posted.
Old Aug 3, 2007 | 11:57 AM
je3169's Avatar
Update: I did an update on Staurday when i got it not sure what the problem was. Last night i set it back to level 2 after messing with the timing and this morning when i got in my truck i set it on level 3 changed my gears and tires and left everything else at what edge set them at and on the ride home it worked great i think i will wait till i use all the gas before i try messing with the timing (i only had about 3gal in the tank then filled up with mobil 93).
Thanks for all the help everybody and i have one more question what gas do you use.
John
Old Aug 3, 2007 | 12:13 PM
If you have Shell in the area, try Shell 93. I have best luck with Shell. I run 93 with timing +1 and sometimes 1.5. I have not had any problems with Shell, Conoco or Texaco.
Old Aug 3, 2007 | 12:16 PM
one other thing, i do bump my idle up to 800-850. Edge recommends 800 to 1000 for level 3.
Old Aug 3, 2007 | 02:41 PM
I have had great luck with shell or cheveron. I prefer cheveron becuase of the additives they have.
Old Aug 3, 2007 | 08:23 PM
Just curious I have mine set at lvl 3 and set the tires, shift firmness ect. however i never changed my timing +1. It runs great but curious whats the +1 on the timing suppose to do or help?
