Newby datalog question
I am preparing to install my LMA-3 and need to know what to use for a tach signal. Do i use a splice from the crank sensor or cam sensor or is there a tach signal wire somewhere in the harness? Thanks for any and all help!
Will
Will
Will
Will
There should be a tach signal or equivalent - don't remote start//alarm systems use a similar input?
Or, you can try the hobbyist approach - a few turns of insulated small gauge solid wire wrapped around a plug wire if you have no COPS), OR a straight splice into the primary COP signal if you do.
Also - you can always just buy Innovate's inductive clamp.
Good luck.
well, i don't think i can use the inductive clamp because of the system being a wasted spark type. i just can't find anything in a wiring schematic that shows a tach signal.
