More ??? about the Edge
Old Jul 12, 2007 | 12:26 PM
Brian840's Avatar
I have a 2006 4.6L with K&N air intake, Magnaflow Single exhaust. I installed the eef2400 and so far I think it runs pretty good on level 2. My question is when I turned it on for the first time to set it with custom options I made the change for the Tire size 295/70/17 = 2654, then I noticed the gear ratio was 3:55. I thought my truck was 3:73 (how do I tell) and if it is 3:73 will it hurt somthing on my truck if I set it to 3:55. It seems to get better MPG and better shifting while having it set to 3:55. I am not sure on what to do, any ideas on this. Thanks Brian
Old Jul 12, 2007 | 12:51 PM
The tire size and gear ratio only control your speedometer and odometer. You need to enter the gears that are actually in your truck. It pops up with a default and if you have something other what it shows, you should change it.
Old Jul 12, 2007 | 05:25 PM
Brian840's Avatar
Okay, I was not sure because I saw the two different values two different times. So if go back into level 2 setup and look at the ratio to verify the setting but not change anything will it reset all my settings?
