Edge...belt slipping
Hey,
Sorry for this question again, I know it's been covered but I just searched and can't find any related threads to it.
Just installed the EDGE over this past weekend. AT least one of my belts are slipping when I slam on the gas. I thought the Gator belts solved this problem but I can't be sure. Can someone let me know if I need to replace both belts or just one, should use a Gator and how hard is the install to do myself.
Thanks,
Thanks,
It,s common with a tuner.A gatorback belt normally stops it.Your truck only has one belt and you need a big a$$ breaker bar to loosen the tensioner,lots of pressure.Very easy to change,diagram under the hood.
My shifting is set to very hard, and the belt slippage is very loud at WOT, though it kinnda sounds like a BOV at lower RPM shifts. I'll prolly get a Gator belt when I get underdrive pulleys.
What exactly is slipping?
You need the Gatorback serpentine belt:
https://www.f150online.com/forums/sh...5&postcount=15
4061015
4061015
JK007, I like how your truck looks. I had a body lift for mine but I sold it because I could not find any pictures of trucks that I liked the look of them with the body lift. I wish I would not have sold it now. Those 35's look pretty good. Sorry to get off subject.
The only thing that I don't like is the 5' bed but honestly, I've had this truck since Feb and I have not needed the extra foot for anything. 2 things I can pretty much bet on:
1. I'll always own a Screw and won't go back to a Scab
2. I'll always have at least a BL on any new truck I get.
I just hope this one lasts longer than my last one.
If you are considering a BL lift again for your Screw, you should do it. I love mine.Take care buddy,
