Top speed limit gone---Superchip
It's hard to tell how fast but after the speedometer stopped gaining it felt like maybe 10 or 15 more mph. It took almost 1/2 mile to get this speed on level road.
Originally Posted by BlacknGold
I must be lucky or something because my 01 does not have a speed limiter.
In reality, you do. Either tires, driveshaft or aerodynamics.
The first two would not be too pleasant ...
Originally Posted by liquid 1
A++++ on the superchip 1715 with the performance tune.and 93 octane
.Its like a new truck..
All truck have the speed limiter. You might just not be able to tell its kicking in. On my older truck I couldnt tell when I hit the speed limiter, but I knew it was there. On my new one it will go pretty good up to 103ish and then it just stops...it will actually lurch you forward in the seat a little when it kicks in and just stops going.
You guys just haven't hit it yet, when you hit around 98mph in a stock truck, it pulses the ignition and injectors and feels like a turd, even on my 4.6L I could feel it stop pulling, man that was depressing...Since my Edge, I haven't been quite as young and dumb (a whole 6 months ago) I haven't tried that or 1/4 mile, I'm too worried I'll find some ***** cop on the empty road by our military base.
On 99 to 03, not sure of the newer trucks, you can bring up a digital display on the odo that shows your speed in mph. This will read past the 100 limit of the dial. My 99 with the limiter lifted hit 128mph. I have the 5.4 3.55 gears 2 wheel with some mods on 16s. I have had it there a couple times.
Sled...
Sled...
Originally Posted by masonball
I know the tuner choice is dependant on the individual, but you obviously like that superchips. What changed after installing it?
Masonball, Its like a new truck, better torque, better throttle response and better power, Ive had the superchip for 4 years and have been running the 87 octane tune, to cheap to run the good stuff, Its a weekend driver, Im fortunate to have a F550 company truck to work in all week,and with gas as high, heck for $0.20 more I can run the good juice, and wow what a change in shifting, pulling power and getup.And seems to me gets better gas milage and ive recalibrated the tire size and speed, when i keep my foot outa it.I just raised my truck 5" , 2" suspension, 3" bodylift..and went from a 265/70R/17 to a 315/70R/17 and I was really surprized at the differance the performance mode made..Before when I gased on it it was like a lag or a tiny bog with the bigger tires, now it goes when I punch it even with 35" tires, If you were local I could take you for a ride, my friends think Ive went to a 4.10 gear, which I was thinking about...
2001 5.4L, 3.55 gears, K&N catback exhaust,K&N FIPK kit with heat sheild..1715 93 octane performance tune
heres a pic..
