Edge Help! Idle rpm's?
okay guys, i may be an idiot for asking but i just got my edge last week. I've been piddling around with a few things. level 3 preset works great but has a really low idle rpm - like 370 or so. even dies out occasionally. i went to custom to change max speed, tire size, etc... but that made the rpm race at 1700 during idle. is this all normal or do i have a big problem? any help would be appreciated. Thanks.
What exactly did you change?
I would be verrrrry careful changing some of the pcm parameters until you understand the interrelationship of the performance options.
I just recieved my edge lat week. I'm running level 1 with axle & tire data modified.
Originally Posted by F150_B.F.D.M.
will changing ur tire specs on the edge help at all except give u more accurate speed?
Originally Posted by bluejay432000
That is all it is for, to set your speedometer and mileage.
idle problem like treekiller!
I got mine today.
I was approaching e on my 87 octane gas, so I decided to play with lvl 1 and 2 on my way to the gas station. My truck worked fine, and I was very impressed with the edge programmer like the rest of you. Since I had to put gas I decided to put 92, that's all Hawaii offer's. It started up w/no problems, and ran great. Drove it around a bit to get rid of the remainding 87 octane, then upped it to Lvl 3, and lvl 3 is for me. But when I got to my stop, I went to reverse into my stall and the truck died out cause rpm's to low 150-300. So I decided to pull forward in to the stall in front of me so I won't hold up traffic. It took me 4 tries to do it, the last try, I had to rev the truck from P to R to N and finally D, and jerk my way forward, (lookin like an A$$
). So I put the edge back to stock and same thing, it rev's to low, still 150-300 for about 3 sec and dies out. I tried to up my rpm's on the tuner but all lvl's only allow up to 350, and that's not enough. Hopefully someone can
us.
us.
I got mine today.
us.
us.Last edited by Jakob Lee; Feb 6, 2021 at 08:02 PM.
