Air/Fuel Ratio
Old Feb 26, 2007 | 10:13 AM
bixbystx's Avatar
Air/Fuel Ratio
This might sound like somewhat of a dumb question but I'm going to go ahead and ask. Does the air/fuel reading that I get stay constant thru the entire powerband? I'm pretty sure that I'm runnning too lean and I just wondered if this is the case.
Thanks,
Old Feb 26, 2007 | 10:22 AM
MGDfan's Avatar
Thanks,
Hi.
No. It'll be stioic initially (closed loop, after the o2's warm up), then go richer somewhat as required when into open loop ( high load, WOT). This is overly simplified, mind you.
What are you reading it with?
You can search for some of the posted dyno graphs to see what I mean.
Cheers
bubba
