Edge freezing up...literally...
Old Jan 26, 2007 | 09:46 PM
00Ford4X4's Avatar
Its been pretty cold here in Jersey the past few days (Well below 20). Got into my truck, started it up, and my Edge said 0 for RPM, Coolant temp, etc.
I think the cold weather really effected its monitoring. I unplugged the Edge and plugged it back in, works fine. This has happened a couple times today.
It also showed the hex file when I started my truck this morning then went back to normal when the truck warmed up inside.
Weird...I really think the cold weather effects the display...
Anyone else had this problem?
Old Jan 26, 2007 | 10:23 PM
Keith460's Avatar
Yeah, got in my truck today after landing back in the Philly airport and I had the same problem with the display freezing. LCD's will do that when they are cold but otherwise the Edge functions normally and displays correctly once it warms up in the cab.
You should see what happens to my laptop when I leave it in the truck overnight in the cold.....won't even turn on!
Old Jan 26, 2007 | 11:19 PM
00Ford4X4's Avatar
Hey, thanks for the info...at least I know my Edge isn't messed up. Truck ran normally, display was just erratic
Old Jan 27, 2007 | 01:41 AM
ieee_raider's Avatar
Mine had trouble with the cold snap we had last week. Similar symptoms.
Old Jan 29, 2007 | 09:17 AM
05supercrew's Avatar
They all do it, nothing to worry about.
Old Jan 29, 2007 | 10:37 AM
Silverfish's Avatar
Mine has done this (blank screen or hex showing) 5 times in 2 weeks and has happened on very cold days. If the lcd was frozen then why does it work if you unplug it and plug it back in after the screen screws up? I think that one of the pins is not making contact due to the cold shrinking things. My Evo did not do this last winter.
Old Jan 29, 2007 | 02:57 PM
Silverfish's Avatar
Received this message from Edge:
Yes, we have been seeing this with the colder weather. If the Evolution does not see enough voltage on power up it turns on in an unknown state. This is why once the truck is running, if you disconnect the Evo and reconnect it the unit should power up normally. Once the engine is running there is enough voltage coming from the alternator for the Evolution to power up normally. The engineers are working to see if there is something we can do for this, but there may be limitations to how the LCD can power up in colder conditions.
Thanks,
Cody Chatelain
Edge Products
1080 South Depot Drive
Ogden, UT 84404
Phone: 801-476-3343
Fax: 801-476-3348
www.edgeproducts.com
Old Jan 29, 2007 | 07:59 PM
00Ford4X4's Avatar
Thanks,
Cody Chatelain
Edge Products
Ogden, UT 84404
Phone: 801-476-3343
Fax: 801-476-3348
Thanks for the info Silver...at least now I know I am not the only one
