Yet Another Edge Q
Yet Another Edge Q
My edge display will not display the eot engine oil temp it just says 0, what can this be and also when I'm driving there is a vibration under my feet and my steering wheel. This vibration I noticed before I programed it but it went away and now it is back. also my idle is high when I first start my truck in the mornning its loud and reads out over 1000 rpms, any thoughts?
I have a faster idle now also. I think it's because of the colder weather. Mine will also jump to over 1000 rpm for a few seconds.
Don't know about the EOT. Mine works fine. I think thats a question for EDGE, or maybe your sensor has gone out.
Good luck.
Good luck.
I believe the higher revs when first starting the truck is normal. I live up in NH and during the winter months when it gets cold, my engine will rev up to around 1200 when first starting and then within about one minute it will settle back down to normal idle. It's been doing that since day one so hence the reason I assume it is perfectly normal. The EOT thing I have no idea about either. Hope someone can help you.
