XCal2 & Tow/Haul mode?
I've had my XCal2 & tunes now for a few weeks and am lovin' em. But I was wondering how my Tow/Haul mode will work in conjunction with the tunes? Should I use it? Or should I just load up my Tow tune when I plan on hauling stuff and leave Tow/Haul mode off?
Originally Posted by Melovidov21
Anybody? Mike?
There is no tow/haul mode...When you want to tow you simply retune your vehicle to the towing tune....overdrive is not an issue.Some use it while towing and some don't.
I was thinking they just held the gears longer, but when I was stock and put it in tow/haul the truck seemed to have more off-idle power.... dunno.
Marc, my truck's a '05 F250 SD... I don't think I can lock-out OD if I wanted.
The tunes really do a number on these, don't they? I'm lovin' mine too.
What lift/levelling kit did you use to fit those 35 inch Coopers?
Hi Melovidov21,
On the SuperDuty trucks that have the Torqueshift 5-speed tranny, your tow-haul mode is not affected by our tuning, it will do exactly what it is designed to do from the factory.
So when towing, load up a towing-compatible tune, and then use your Tow/Haul mode however you like, just like you normally would!
And just a quick FYI so you'll know for future purposes, as we point out in the docs that we send out with our tunes - any time you are trying to get information from us in a timely manner, the thing to do is to call us. We get by here as often as possible, but this is not where we provide Tech Support - that is done only by phone or in person, so any time you need quick info, please just give us a quick call so we can help you as quickly as possible.
Thanks for your post, & have fun!
