diablo sport programer
Old Dec 16, 2006 | 09:35 PM
ivrodriguezfx4's Avatar
i drive a 06 5.4 fx4 Screw i have the diablo sport programmer i am kind of familiar with the programer but does anyone knows how to get the best of the best on the programmer PARAMETERS) I am not familiar with the spark timimg fuel.i only had change the speed limiter,shift presure,shift points,and thats it pretty much need Thakns in advanced.
Old Dec 19, 2006 | 02:25 AM
Hash278's Avatar
I have the same programmer and have made the same adjustments on the shift presure and points and my truck has been running great. I dont think you need to mess with the spark timing unless some recommends some good adjustments. There is also an update for the programmer at diablosport.com if you havent updated already.
Old Dec 19, 2006 | 07:02 AM
marwilli1's Avatar
i used to have a diablo i never got into the parameters that much simply cause it took so long. i finally said screw it and got an edge, and i love it the truck just seems to run/shift alot better and smoother. i know this isnt much help for your original question but getting the edge will solve that problem
Old Dec 19, 2006 | 09:13 AM
05supercrew's Avatar
x2 I personaly dont like diablo. Problems with them and there programers in the past.
Old Dec 19, 2006 | 01:43 PM
Hash278's Avatar
Edge
One question about the edge,does it mount onto the dash board or is it like superchips or diablo. I have a diablo and have been contimplating a change. Thanks
Old Dec 19, 2006 | 08:55 PM
marwilli1's Avatar
it mounts to the left of your gauge cluster, but you can also just install the tune then take it out, if you like. do some searches on here or google and you will find pics. I highley recommend the change from diablo, you will love the edge
Old Dec 20, 2006 | 01:04 AM
Hash278's Avatar
Thanks for the info partner. One more question though what do you know about the jet performance module, is it the same as a programmer or can it be used with a programmer.
Old Dec 20, 2006 | 09:23 AM
Take a look in my gallary.
