Edge Evo on Level-3
Old Nov 18, 2006 | 10:12 AM
fanman1964's Avatar
Question Edge Evo on Level-3
First off, I'm new to the site, best site for info and more THANKS !!!
I received and installed my edge tuner about three days ago. But I do have two questions, first I have a 2005 f150 with a 5.4 and I wanted to know if there is any recommendations on how many time you can program in a day or two with out causing damage (trying to find the sweet spot ). And second I was wondering if anyone has noticed when programmed on level-3, have felt that when slowing down the transmission shudders not slips. Any info would greatly be appreciated.
Old Nov 18, 2006 | 11:35 AM
Adam06FX4's Avatar
Registered User
you can program as many times as you want. you will notice some drivability issues untill the pcm learns its new programing. i find it takes a good couple days after programing. also make sure you update your edge if you havent already
Old Nov 18, 2006 | 11:45 AM
HiVoltage14.4's Avatar
How do you go about doing the update process? How do you know if it is already updated? Im ordering one in a couple of weeks.
Old Nov 19, 2006 | 12:30 AM
00Ford4X4's Avatar
Cool
I noticed the same with my edge that the transmission does shudder a bit when slowing down at higher speeds (50-60 MPH). I agree with Adam06FX4 that its does take a couple days or so for the PCM to learn its new program. I even noticed this when I returned it to the stock settings when I took mine into the dealer. After 2 days, my trans shifts fine.
I really do not think its anything to be concerned with. But, their is a wealth of knowledge from others folks on here that may be able to help you also.
Old Nov 19, 2006 | 10:22 AM
fanman1964's Avatar
Thanks for the info. It's good to have all the wealth of knowledge of everyone here. Does seem to be better after one day.
