New Edge User
New Edge User
So I just got my Edge Evolution installed and have not mad any changes yet. What do you guys feel I should have my settings at? Anything I should change right away or not change.
My 2005 F-150 Supercrew is running:
K & N Intake
MagnaFlow Dual Exhaust... dual from muffler.
35 x 13.50 on 20's
6" FabTech
Rear add-a-leaf
Everything else is stock I think.
Thanks!
K & N Intake
35 x 13.50 on 20's
6" FabTech
Rear add-a-leaf
Thanks!
You need to go into the custom setting and adjust for the size of tires and make sure the gear setting is correct. That can be done on either level 2 or level 3. Then it is up to you. Most of us are doing something close to the following:
If running 93, we bump timing up 1.00
WOT shifts: 1-2=5250 2-3=5250 3-4=4800
Max RPMs: 5600
Shift Pressure: +12 or however firm you like it
WOT Fuel: +1.6
Max RPMs: 5600
WOT Fuel: +1.6
Originally Posted by 00 4x4
Anybody know if the custom settings are available for the 97'-03' edge?
With your Edge installed, when you turn the key on and punch the top button on the monitor, it should give you several options. the first one is to reprogram, you select that then it should ask if you want to customize, you say yes and then it asks if you are sure, you say yes and the next screen should start the custom options.
Thanks, I'll try that. I spoke with Edge and they said I may have held the button down too long and skipped the custom options prompt on the initial install. Haven't tried to reprogram yet so I'll give it a whirl.
Max RPMs: 5600
WOT Fuel: +1.6
Max RPMs: 5600
WOT Fuel: +1.6
Originally Posted by sebenza
When you say 93... are you referring to Octane? I live in Colorado and I think the high octane here is 91.
Originally Posted by djh1121
sebenza - do you have any pics of your truck?
https://www.f150online.com/galleries....cfm?gnum=8645
