EDGE - Speedo problem
Old Nov 3, 2006 | 09:31 AM
Brosh's Avatar
Hey guys, first post. I just bought a 2006 5.4 F150 and a edge. I hooked it up yesterday but when I put in on the 1st setting the speedometer is way off! When I go 15 mph is says I'm going 80. When I change it back to stock it is fine.
How would I fix this? Would I have to do a custom change? I have stock tires and 3.73's.
thanks!
Old Nov 3, 2006 | 09:35 AM
06FX4's Avatar
maybe check the setting? to make sure the gear ratio and tire size things arent screwed up. .
Old Nov 3, 2006 | 09:37 AM
kd4crs's Avatar
Did you go into custom options? If you did, you must set the actual gear ratio and actual tire size of the vehicle. Just looking at the custom options will clear out what the PCM settings are for these 2 items.
Old Nov 3, 2006 | 09:43 AM
Brosh's Avatar
I didn't go into the custom settings at all. But I will check out the settings durning my lunch.
thanks again, I can't beleive how fast I got replys!
Old Nov 3, 2006 | 01:20 PM
Brosh's Avatar
Ok I checked all the settings and everything is right, the gear ratio and tire size were correct...
I tried both the #1 and #2 this time. And for both make my speedo is still way off.
I gave Edge products a call, but no one answered after 30 mins, so I left a message.
Old Nov 3, 2006 | 01:27 PM
06FX4's Avatar
did you update it when you got it?
Old Nov 3, 2006 | 01:29 PM
kd4crs's Avatar
I haven't read about anyone having this problem. Keep us posted, I've got an 06 and my EDGE is working fine. Did you update the unit over the internet before installing it?
Old Nov 3, 2006 | 03:23 PM
Brosh's Avatar
I didn't update it first... I'm going to try this when I get home. I downloaded the program, just didn't update the EDGE yet.
I'll keep you guys posted
Old Nov 4, 2006 | 11:42 AM
Brosh's Avatar
problem after problem.
I downloaded the software and updated my EDGE. When I installed it back in my truck and put it on the 2nd setting it gives me this error.
sorry about the pic, camera phone
So I uninstalled the lighting program and reinstalled it from the site and I got the same problem again. THis sucks... and I can't call EDGE Products until Monday!
Old Nov 4, 2006 | 04:41 PM
MosineeFX4's Avatar
What versions did you download? I've been running the latest versions 20 & 21 (beta) without any problems. What is your hex code? I know on the edge website it lists the supported hex codes, you may want to go there and check it out. The list comes up with other version info when you select the updates selection. Did you make sure the key was in the on position when you plugged the unit in? If not I would try to hook it up again. I recall getting an error a while back and I believe that I had tried to plug the unit in when the key was off. Hope everything works out for you.
Old Nov 4, 2006 | 04:50 PM
BlueOval Breath's Avatar
Hello... Same error I had. The problem is you updated to the incorrect version of software. You need to reconnect to the pc and update as the previous post reads... Version 20 and 21(beta). these are for the NEW 06 trucks. I had the same issue and it was resolved by loading the.. 20 and 21 (beta) version. BoB
Old Nov 5, 2006 | 09:02 AM
Brosh's Avatar
Ok thanks a lot guys! I'll try that out.
Old Nov 6, 2006 | 10:15 AM
Brosh's Avatar
Ok.. I reinstalled the new one Version 20 and 21(beta). I got the same problem... So I figured it must be my computer.
I went to my GFs house, download the software and updated the EDGE from her computer. Same error....
I'm going to give EDGE products a call again. Hopefully they answer this time
Old Nov 6, 2006 | 10:44 AM
MGDfan's Avatar
Hi.
Well... the x2 Group buy is still in effect...
It's still not too late
Good luck.
Cheers
Bubba
Old Nov 6, 2006 | 02:13 PM
Fire604's Avatar
Before updating the software, did you return your truck to the stock tune? If you left your truck tuned, removed your Edge and then updated it screws up the program.
