Edge Evo
Old Oct 24, 2006 | 08:52 PM
AustinFX4's Avatar
Edge Evo
I have had the Evo for about a month now. It seems to me that level 2 offers more power?? I ran Level 3 with no custom tune and the 0-60 time was slower than Level 2 with 91 octane (tested one after the other). Also, I swapped a set of 18" stockers for my 17" stock FX4 wheels. When I corrected the tire size, my speedo was off more than before the correction. Any input on a good custom tune would be greatly appreciated. Thanks..
2005 FX4
5.4 L
3.73
Flowmaster Cat-back
K&N drop-in
Edge Evo Level 2
2" Auto spring kit
Old Oct 24, 2006 | 09:30 PM
Silverfish's Avatar
read my signature for settings I use....
Old Oct 24, 2006 | 11:41 PM
bamorris2's Avatar
I recall seeing on these boards several posts saying the same thing: they get more power on Level 2 setting... But when I had the EDGE, I felt there was more power on Level 3.
Old Oct 24, 2006 | 11:47 PM
AustinFX4's Avatar
Edge Evo
I'll try the custom program that Silverfish mentioned in his signature. I am happy with the improved shifting and throttle response as is, but would like to see what it could do with some tweaking. Thanks for the info.
Old Oct 25, 2006 | 08:04 AM
redrascal's Avatar
When you adjusted the tire size did you adjust the gearing also. I had read the if you change one you have to change the other. That maybe why your speedo is off.
Old Oct 25, 2006 | 08:52 AM
Silverfish's Avatar
That is no longer an issue......
https://www.f150online.com/forums/sh...75#post2062675
Old Oct 25, 2006 | 09:16 AM
You change the gearing if the gearing that pops up is different from what you have. Mine was different, so I have to change it. Also, there is no way my Level 2 is even close to my Level 3. I stay on level 3. I use pretty much the same settings as Silverfish. I am going to have to go back to stock in a couple of weeks to get an inspection. That will be interesting. Will be the first time back to stock since I got the Edge about 5000 miles ago.
Old Oct 25, 2006 | 11:05 AM
05supercrew's Avatar
I agree my lvl3 is so much better then lvl2, not even close.
